Old 02-08-2010, 11:52 AM   #95 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Christ View Post
Unfortunately, glass exit pipes (it's not a downtube if it's pointing up...) wouldn't last very long... if the thermal shock didn't break it, it would melt under full load, at least start sagging.
Turbo's can spin up over 100,000 RPM under full boost conditions, and exhaust temperature can reach over 1,000* on the hot side of a cartridge. Oil coolers should not be overlooked in this case!
Via reading and watching/working on tuners and race cars, I've picked up on a cute euphemism for turbochargers in general - Lubricant Hell.
Your right. Oil temps and type are a major concern.
Originally Posted by Funny View Post
Putting the exhaust through the hood is obscene... I love it! I am guessing that that will not be passing emissions or being used for street... You could always Y it off to the standard exhaust, right?
It will be a Y with one going to the normal exhaust and it will pass are emissions. Lucky we don't have a visual modification.
Pressure Gradient Force
The Positive Side of the Number Line
