Old 02-07-2010, 05:09 PM   #91 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
You may have to use varsol as your windshield wiper fluid!
The only way that could be better is if you could see the impeller from the cockpit to watch it spool up.
Awesome!
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 02-07-2010, 05:15 PM   #92 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Unfortunately, glass exit pipes (it's not a downtube if it's pointing up...) wouldn't last very long... if the thermal shock didn't break it, it would melt under full load, at least start sagging.
Turbo's can spin up over 100,000 RPM under full boost conditions, and exhaust temperature can reach over 1,000* on the hot side of a cartridge. Oil coolers should not be overlooked in this case!
Via reading and watching/working on tuners and race cars, I've picked up on a cute euphemism for turbochargers in general - Lubricant Hell.
Old 02-08-2010, 09:47 AM   #93 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Putting the exhaust through the hood is obscene... I love it! I am guessing that that will not be passing emissions or being used for street... You could always Y it off to the standard exhaust, right?
American by right
Ecomodder by choice
Hypermiler by necessity
Old 02-08-2010, 11:47 AM   #94 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Awesome!
Wait until you see it on anti lag.heheheh
Pressure Gradient Force
The Positive Side of the Number Line
Old 02-08-2010, 11:52 AM   #95 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Your right. Oil temps and type are a major concern.
It will be a Y with one going to the normal exhaust and it will pass are emissions. Lucky we don't have a visual modification.
Old 02-08-2010, 02:33 PM   #96 (permalink)
To be added to parts list:
Old 02-08-2010, 03:58 PM   #97 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Haha
Old 02-08-2010, 04:38 PM   #98 (permalink)
stonebreaker's Avatar
Hey, have you heard about a program called Desktop Dyno? I use it a lot to compare various performance modifications. Seems to me it would benefit your situation by allowing you to test a lot of virtual cams. The rest of your stuff sounds like it would be rather difficult to translate to the programming parameters, but the cam stuff should still work pretty well.
And this whole thread is cool as hell.
Old 02-08-2010, 05:57 PM   #99 (permalink)
I have that program... the free version of it doesn't work all that great, and it takes forever to perform even low-resolution tests with multiple iterations, but it gives you an idea, I guess.
The paid version, supposedly, has much more "tunability" to it, so it should be more accurate.
Neither version allows "weird" stuff, though, like offset mains and such, or multiple cam profiles (a la Vtec, etc.), and things like that, and the free version doesn't give (as far as I know) any variability on AFR's, it just assumes that you'll be running in a "normal" way.
Old 02-08-2010, 06:10 PM   #100 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Ceramic glass can take 1000˚C and is resistant to thermal shock. I have windows on my kiln that regularly go to 1450˚F with room temp on the other side. They can formulate it to match the coefficient of expansion of the metal you are bonding it to and there are agents that can bond it to metal. No problem!
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 04:44 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 01:07 AM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 03:32 AM
Video: Armory Lovins, Rocky Mountain Institute - promoting design of efficient cars Smoky Aerodynamics 6 05-10-2008 05:06 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
