Originally Posted by stonebreaker
Hey, have you heard about a program called Desktop Dyno? I use it a lot to compare various performance modifications. Seems to me it would benefit your situation by allowing you to test a lot of virtual cams. The rest of your stuff sounds like it would be rather difficult to translate to the programming parameters, but the cam stuff should still work pretty well.
And this whole thread is cool as hell.
I have the software on my older computer. I do use it on some situations.
The biggest tuning aid I'm using now is a spreadsheet I made from Ben Straders EFI 101 class. I have made a few versions of it and now have one that helps me with BSFC on throttle light load.
Thanks for the kind words!!! I'm to a Hot Rodder with a racing back ground, and now have falling for the fuel economy/performance side of the coin.
