Old 02-08-2010, 06:42 PM   #101 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by orange4boy View Post
Ceramic glass can take 1000˚C and is resistant to thermal shock. I have windows on my kiln that regularly go to 1450˚F with room temp on the other side. They can formulate it to match the coefficient of expansion of the metal you are bonding it to and there are agents that can bond it to metal. No problem!
Coolest thing I've ever seen was a glass door on a wood stove implode into the stove and about 60 foot flames coming out of the chimney. Creosote fires are awesome, as long as they're not happening in your home.
I knew about glass like that, but jeez, that'd be expensive for an exit tube!
Old 02-08-2010, 09:28 PM   #102 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by stonebreaker View Post
Hey, have you heard about a program called Desktop Dyno? I use it a lot to compare various performance modifications. Seems to me it would benefit your situation by allowing you to test a lot of virtual cams. The rest of your stuff sounds like it would be rather difficult to translate to the programming parameters, but the cam stuff should still work pretty well.
And this whole thread is cool as hell.
I have the software on my older computer. I do use it on some situations.
The biggest tuning aid I'm using now is a spreadsheet I made from Ben Straders EFI 101 class. I have made a few versions of it and now have one that helps me with BSFC on throttle light load.
Thanks for the kind words!!! I'm to a Hot Rodder with a racing back ground, and now have falling for the fuel economy/performance side of the coin.
Pressure Gradient Force
The Positive Side of the Number Line
Old 02-08-2010, 11:14 PM   #103 (permalink)
stonebreaker's Avatar
mentioning the spreadsheet reminded me of something. May or may not help, but the info's interesting nonetheless.
http://www.gnttype.org/techarea/turbo/turbocalcs.xls
Old 02-09-2010, 02:11 AM   #104 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thanks I'm a collector of spreadsheet automobile tuning. Yeah a freak.LOL
Old 02-11-2010, 11:34 AM   #105 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Originally Posted by pgfpro View Post
I'm running Neptune engine management. I write all my own the values. I never run in closed loop. I tell what I want my ECU to do. The O2 sensor is nothing more then a gauge now along for the ride.
etc...
It looks like they only make it for Honda's, its hard to tell as parts of the site don't work. I think I have found one for my Jeep though.
Have you tried injecting a little H2 into the engine to help lower your AF ratio?
From what I understand it should increase the flame speed, and make it easier to ignite.
edit to add: running open loop all the time is throwing me for a loop.
Old 02-11-2010, 01:44 PM   #106 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
I feel like a misfit on her sometimes and I'm not to sure if I'm even on the right forum??? (performance+ Fuel economy = LOVE)LOL
Haha, you are not alone. I'm constantly researching mods for more power and efficiency from my TDI. However, the performance is clearly on a different level to your del sol. I don't exactly have the time or resources to entertain a build like yours, either.
However a well built/tuned big turbo TDI should be able to hit 250 WHP and maintain 60+ mpg in an aero-modded VW.... lesser goals for both performance and economy... I know, I know..
Awesome stuff here though. Haven't been around the site so much recently but this thread is fun to watch. Can't wait to see the #'s!
Old 02-11-2010, 02:57 PM   #107 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Neptune is a Honda only system.
I'm not to much into H2.
Open loop is where it reads and runs off pre-programed load/rpm tables. The values in these tables are my inputs. The O2 sensor doesn't adjust anything on my system.
Old 02-11-2010, 02:59 PM   #108 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Cool another one like me.LOL
I would love to do a TDI performance/economy car also. Just not enough time as of right now.
Oh and Thanks
Old 02-11-2010, 03:51 PM   #109 (permalink)
TheEnemy's Avatar
I'll probably be asking more detailed questions latter on in the year when my project starts nearing the programming stage.
The research I have been doing prior to rebuilding the engine is what lead me to this site and your thread.
My plans are a bit different than yours though but with similar end results.
Engine block Jeep 4.2L I6
Head Jeep 4.0L I6 with multipoint fuel injection.
Head work to include minor port work (mostly cleaning up casting imperfections and to get the air to swirl in the cylinder)
chamber and valve coatings to help keep detonation down
12:1 compression
Long tube header
Roller cam with good low to mid range performance
My targets are
250hp under 4500rpm
300flb torque under 3500rpm
25mpg at 75mph (if I get results similar to what you are trying for it could be as high as 30mpg which would be impressive for a cinderblock)
1gph when on the trails (with what I'm learning from you it might get as low as 0.5gph, the 4cyl 2.4l in my pickup burns 1gph)
Old 02-11-2010, 04:28 PM   #110 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
12:1 compression
Long tube header
My targets are
250hp under 4500rpm
I will be glad to help in anyway I can. Sounds like you have done your research on your project. Looks like it will be fun!
Heres a pic of my low cam fuel map with raw numbers that I change while tuning.
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 04:44 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 01:07 AM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 03:32 AM
Video: Armory Lovins, Rocky Mountain Institute - promoting design of efficient cars Smoky Aerodynamics 6 05-10-2008 05:06 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
