Old 02-11-2010, 01:16 AM   #52 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by Christ View Post
Fuel for fuel, there probably are instances where it's actually cheaper to run a car, even if you don't consider the actual impact of each fuel source.
That's true, but it's a minimum of two passengers, run on a compact diesel using WVO IIRC to get to see lower costs than a frugal cyclist/shopper. Everything else is more expensive.
Remember, food takes more fuel to make, deliver, buy, and consume than fuel does.
That's not necessarily true. Sometimes it is, sometimes it isn't. It depends on the fuel versus the food.
