Old 02-11-2010, 03:51 PM   #109 (permalink)
TheEnemy
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Originally Posted by pgfpro View Post
Neptune is a Honda only system.
I'm not to much into H2.
Open loop is where it reads and runs off pre-programed load/rpm tables. The values in these tables are my inputs. The O2 sensor doesn't adjust anything on my system.
I'll probably be asking more detailed questions latter on in the year when my project starts nearing the programming stage.
The research I have been doing prior to rebuilding the engine is what lead me to this site and your thread.
My plans are a bit different than yours though but with similar end results.
Engine block Jeep 4.2L I6
Head Jeep 4.0L I6 with multipoint fuel injection.
Head work to include minor port work (mostly cleaning up casting imperfections and to get the air to swirl in the cylinder)
chamber and valve coatings to help keep detonation down
12:1 compression
Long tube header
Roller cam with good low to mid range performance
My targets are
250hp under 4500rpm
300flb torque under 3500rpm
25mpg at 75mph (if I get results similar to what you are trying for it could be as high as 30mpg which would be impressive for a cinderblock)
1gph when on the trails (with what I'm learning from you it might get as low as 0.5gph, the 4cyl 2.4l in my pickup burns 1gph)
