Thread: 50 mpg!
Old 02-12-2010, 04:26 PM   #12 (permalink)
90crxHF
Si engine and trans
90crxHF's Avatar
CRX Si/HF - '90 Honda CRX HF
90 day: 40.35 mpg (US)
Originally Posted by Old Tele man View Post
...I wouldn't dispute his numbers, but I would have more confidence after a second and third "confimation" set of numbers.
...an average of one might be suspect, but an average of three is nearly indisputable.
...and, FWIW, the SGII is certainly NOT a truly "certified calibration" device--but, it certainly *IS* far, FAR better than nothing.
See, I'm trying to not go there and say, your numbers are wrong, re-test!! No, I'm simply asking how they actually fill their tank up....
For me, I use the same gas station, same pump, same grade, and parked in almost the exact same way each time. I also try to fill up in the same time of day, but still temperatures, baro, humidity all come into play and can affect exact fill up numbers.
However, giving everyone the benefit of the doubt, I'm sure you guys fill your cars as exacting as the time before??
~1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race
1/8th: 9.90 @ 71.03, 60' - 2.41 (HMP '08) - 284K on chassis and ~110k on engine
~1996 Mustang GTS/248A - 1/4: 13.447 @ 99.75, 60' - 1.820 (HRP - 959' DA)
http://www.nearlysurrounded.com <-- Check out my band
