Old 02-13-2010, 01:06 AM   #12 (permalink)
landspeed
EcoModdin' Lurker
Bluey II - '89 Nissan Bluebird 2.0iZX
The SuperMID has a capacitor, so, you can switch it off and on and it won't forget information. The exception being if you unplug the RJ45 cable (the network cable it uses between the two boxes), and the power flickers on and off during the unplug.
I just have a little switch on the dashboard, which I use to switch power to the SuperMID on and off (the only rule is, once you switch it off, dont switch it on for 20 seconds so you dont mess up the Flash memory).
The other thing with the SuperMID is, the version I have is strange, as only the bottom two rows of information change based on the distance / fuel injector parameters, so, you end up with two different calibrated areas. Mine is also km/l. Is your one set to MPG? and when you change the fuel figures, do *all* the readings change in terms of their calibration?
I would take the advice of the posters above, in that you should fill the tank up to the brim, reset SuperMID to zero, then use 80% of the tank, then refill to the brim again, and then post here what the SuperMID said in terms of your distance and fuel used, and what distance you actually drove, and how much fuel you actually used, then we can post new settings for you to put into SuperMID!
Make sure you dont change settings during this tank, and, even before you get it calibrated, just try to improve on the reading, whatever that reading is, on each journey, and you will know you are improving your economy anyway!
1989 Nissan Bluebird Auto - slowly becoming more economical and more extreme
