Could I further press my luck by asking for a 5 second delay between the throttle hitting zero and the pin going low? Just dont want the contactor cycling all the time. Thanks again.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
