Old 02-15-2010, 06:41 PM   #1 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Even shaft seals are getting ecomodded...
Attributing increasingly stringent US fuel economy (CAFE) rules as the motivation for the development...
...one of the largest suppliers of seals for rotating shafts, says it has developed a new design that reduces rotating friction by as much as 75%. If incorporated on all the seals on a typical OEM powertrain—including the engine, transmission, axle and bearing—the new design could improve fuel efficiency by about 2%, according to the supplier.
Source: Shaft Seal Design Boosts Fuel Economy | The Carlovers Magazine
The seal design also apparently:
  • removes the need for a steel pressure ring
  • reduces heat build up, extending life
  • is being used in one un-named new engine
Frank Lee (02-15-2010)
