Old 02-15-2010, 07:48 PM   #11 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Great Job! If I were you, I would put holes in the bottom in order to let rain water drain out. I noticed that my Saturn's plastic running board is hollow like yours and has "unused holes", so I figured drainage was the reason.
1) Thanks
2) I did do that on the second one. I cut a 1 x 2 tab and pushed it through the bottom to form a little exit ramp, chamfered a bit off the end for the water. That way the spray from the wheels cannot enter as easily.
Darn, I should have left it whole so I could use them for extra flotation for my amphib-prius project.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
