Old 02-16-2010, 09:34 PM   #25 (permalink)
Johnny Mullet
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
For the oil pan, don't use a gasket. Just use RTV Silicone. There is a little plate between engine and trans that needs removed, and then drop all the oil pan bolts. Clean it up, lay a nice bead of RTV around the pan and install.
For the compression issue, you need to get stainless steel exhaust valves and head bolts from 3Tech Performance and pick up a head gasket kit with valve stem seals, timing belt, oil, and a filter. Then you need to visit either metroshultz or me or another mechanic nearby for a head rebuild. You may want to consider getting rings and doing the bottom end also.
Good luck!
GeoMetroforum.com - got mpg?
