Old 02-21-2010, 08:37 AM   #91 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by zoltanbod View Post
I looked at the modded impact.Looks like the nose on the Zoleco a longer gentler arcing point along with my my hood.My windshield slope is 28 degrees up the center,can't tell on the impact.My windshield arc continues into and over the roof and falling away down the back window at a gentle 17 degrees.the sides of mine taper in from the front axcle to the tail at 24 degrees.My wheel openings are smoother.The half tear drop shape theoretically has a Cd of .09,so for argument sake lets guess mine at .12,so i think that caculates out to a 27.9lbs drag at 65mph? What do you think? I can hardly wait to do real world testing and compare it to our speculations.
But the half tear drop at 0.09 lacks ground clearance, wheels, panel gaps, door handles, a mirror, wipers, and a radiator.
Drag force is not as interesting as drag power, P=0.5*Cd*A*rho*V^3, and for Cd=0.15, it's 6HP @ 65mph.
Jason's right: you're going to want to check for flow separation on your body plug. If it's present over more than a few square feet, you may want to lengthen the body.
