Old 02-22-2010, 02:10 AM   #97 (permalink)
zoltanbod
Tuft testing.
Originally Posted by JasonG View Post
It seems the rear shape is too abrupt.
I predict detached air flow. 23 deg is too steep.
Try to take it for a drive with the old drivetrain and do some tuft testing before you commit to a mold.
The 23 degree taper from just behind the front wheel area to the rear is in a slight arc for an average of 23 degrees.I will be flow tuft testing this area along with the rest of the body and will fine tune areas if required.Thanks.
Zoltanbod's Photo Albums
