Old 02-22-2010, 04:29 PM   #33 (permalink)
ahanix1989
Send a message via AIM to ahanix1989 Send a message via MSN to ahanix1989
You guys are probably right.... once the thermostat opens it has a tendency to drop pretty low for up to ten minutes. If it's below 10°F out it can spend the entire drive just barely above the lowest 1/3-mark.... rather than halfway between 1/3 and C when normal.
Is there any way to determine when my engine is in "open loop" mode? Is there a certain trigger I can tap into?
