Old 02-23-2010, 11:06 AM   #8 (permalink)
Dark Overlord
Hi,
The ECU2 should provide the vehicle speed (the Front/Rear Left/Right speeds are for ABS). There is no mention of the injector signal... Try to find a proper Service Manual or wiring diagram online... I'm sure it's out there somewhere and I'd be happy to have a look at it for you. Worst case, you could tap injector signal from an injector, but I really don't recommend this.
Tony.
