Old 03-26-2008, 09:41 PM   #12 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
I'd treat a hotter thermostat as a slight, unquantifiable gain. The theory's all there, but it's just not something that I'd expect to actually be able to see in my gas logs.
Sure you may see a difference if you bump up the temps a few hundred degrees, but at only +10º you aren't likely to see much.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
