03-26-2008, 08:27 PM
#11 (permalink)
I read about a racecar inventer one time that created an engine that would produce 2-3 times the horsepower as his competors with the same displacement engine because it ran at 400-500 degrees F. Problem was it wouldn't reliably make it through a single race. I'll try to find that article, but it was several years ago that I read it.
The carnot cycle, like the stirling cycle, is more efficient when run a higher temperature and higher differential. In the stirling cycle I know it's because it provides greater expansion, but I'm not sure if it's the same in the carnot cycle.
Edit: It's crazy how hard it is to find an old article about a hot engine. I'm usually pretty good with google, but all I'm coming up with a bunch of people whining about their car overheating. Does anybody know what I'm talking about or remember any more?
03-26-2008, 08:41 PM
#12 (permalink)
Awesomeness personified
I'd treat a hotter thermostat as a slight, unquantifiable gain. The theory's all there, but it's just not something that I'd expect to actually be able to see in my gas logs.
Sure you may see a difference if you bump up the temps a few hundred degrees, but at only +10º you aren't likely to see much.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
03-26-2008, 09:11 PM
#13 (permalink)
I put a 203 degree stat on my 7.3 and got a consistent 0.5 MPG increase. Not bad for such a cheap mod.
I also use Evans NPG coolant. This is a nonaqueous mixture of 10% ethylene glycol and 90% propylene glycol. It boils at a temperature over 400 degrees. I use it to defeat the cavitation problem common to 7.3s, but I have always wondered: "What if I could get a 300 degree stat?" One thing for sure: My heater would burn my fingers off. Even on the coldest days I have to temper the heater supply air.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
03-26-2008, 10:11 PM
#14 (permalink)
Bypass the rad and find out
03-26-2008, 10:21 PM
#15 (permalink)
I"m not lurking!
That would be great. You've got the coolant problem covered. What about rubber seals at 300*F?
Roll on,
Stew
03-26-2008, 10:54 PM
#16 (permalink)
Thats pretty much what I was thinking.
03-26-2008, 11:19 PM
#17 (permalink)
Still didn't stop me from putting in a 195º thermostat
Every little bit helps.
03-27-2008, 12:44 PM
#18 (permalink)
Liberti
If that is the case, have any of you considered ceramic coating the cylinder walls/pistons? I know ceramic engines have been developed by Nissan, Toyota, and Isuzu during the 80's that showed extreme efficiencies.
Ceramic Engine
They never took off due to the brittle nature of ceramics and the fact it was like machining diamonds, but the concept is there. It seems the theory behind bumping up the thermostat is present, why not take it a step further...
- LostCause
03-27-2008, 12:50 PM
#19 (permalink)
I'll answer that one. Money.
My thermostat needs to be replaced anyway, so I might as well use a more efficient one.
03-27-2008, 12:58 PM
#20 (permalink)
EV OR DIESEL
Going from 160 to the 190 (stock) was a big improvement in the tdi.
Ceramic coatings could improve efficiency . . .
Best credit I can give to ceramic coatings is
A friend of mine had Ceramic coated piston tops (7mgte heavily modded) he was running lean (before the days of cheap wideband o2's) and he melted his cylinder head. (yes that big beefy chunk of aluminum melted holes clean through) and the pistons live on in another motor. So yes, ceramic coatings can do amazing things, if I was to build a motor they would go on everything.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
