One other thing I discovered during this project - If you want to make a sheet of coroplast but just have normal size signs, like I do, you can connect them top to bottom at least by putting wire through the holes in the corrugation. I connected 4 signs together to make the belly pan on this rigid. I had a scrap piece of 12 gauge, solid core electric wire (like for your house) and split up the 3 wires and slid them (spread out to 3 different "slots") through the signs before taping the junctions with duct tape. My old belly pan fell apart because it was just taped; this one will not have any trouble. You could probably use a wire clothes hanger if you straightened it out first too.
Oh, and if you are attempting any work with Coroplast, you need to get two things to go with:
Gorilla Tape (the black stuff) It's awesome and has held up for over 2 years on my side skirts
Krylon Fusion spray paint (hardware stores sell it) - it sticks to plastic!!
