Old 03-26-2008, 10:11 PM   #13 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I put a 203 degree stat on my 7.3 and got a consistent 0.5 MPG increase. Not bad for such a cheap mod.
I also use Evans NPG coolant. This is a nonaqueous mixture of 10% ethylene glycol and 90% propylene glycol. It boils at a temperature over 400 degrees. I use it to defeat the cavitation problem common to 7.3s, but I have always wondered: "What if I could get a 300 degree stat?" One thing for sure: My heater would burn my fingers off. Even on the coldest days I have to temper the heater supply air.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
