My 37 Ford had a starter button on the dash and a keyed ignition switch on the steering column. Locked the steering wheel also.
You could crank the engine until it had oil pressure, then key on the switch and start it up. Manual choke and separate throttle pull buttons on the dash below the radio.
regards
Mech
