Old 02-27-2010, 11:20 AM   #8 (permalink)
moorecomp
My summertime inflation pressure is 44psi also. The sidewall max is 35psi. I have checked after driving, and even on a hot summer day, the pressure was no higher (I use a dial type gauge, not cheapo). The higher initial pressure reduces the flex in the sidewall, and thus reduces the increase in tire temperature. 'Stiffer' tires run cooler. Here's my old thread about when I measured my tire wear recently.
http://ecomodder.com/forum/showthrea...ear-10265.html
