Old 09-20-2009, 09:34 PM   #1 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 39.53 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 23.7 mpg (US)
Measured my tire wear
I bought my ZX2 over a year ago with these tires on it. I am not sure how many miles they have total, but I have been running my Michelin Rain Force MX4 tires for over a year now (20,000+ miles) at elevated pressures (38 initially now 44). The other day I was working on a noisy brake and decided to measure the tread depths of the tires to see how even the wear is. I measured each of the three grooves in the front and rear of the tire using a depth caliper and averaged the readings. Here is what I found:
LF:
Inner-.207
Middle-.220
Outer-.197
RF:
Inner-.217
Middle:.230
Outer-.215
LR:
Inner-.225
Middle-.235
Outer-.220
RR:
Inner-.205
Middle-.215
Outer-.195
Interesting how even at the elevated pressure, the middle still has the most tread remaining and the outers wear slightly more than the inners. Maybe if I raise the pressure a little more, the wear will even out to the middle?
Thought? Any one else measure theirs and post results.
FYI: New, these tires had .320 tread depth.
moorecomp
Mancelona, MI
Old 09-20-2009, 10:13 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I always thought they just expanded to the diameter of the steel belts, so that they don't bulge in the middle like a balloon with additional pressure.
So wearing on the edges is normal as they are the "front line" when cornering.
Old 09-20-2009, 11:25 PM   #3 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
I measured a couple new sets when I got them and found they had deeper tread in the center when new. So in my own use I'm not aiming for even tread across the width. I do suspect that higher pressure won't cause (much) reduction in center tread depth.
Mine are rated 44 psi; I'm running them at 50. Still have deeper tread in the middle after about 25K miles put on the tires which I bought new.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 09-21-2009, 12:28 AM   #4 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 18.11 mpg (US)
Heep - '011 Grand cherokee Larado x
90 day: 19.31 mpg (US)
Da bike - '06 Shadow Vlx deluxe
90 day: 53.94 mpg (US)
that is really good,
i wore out my current set from 1-16-09 to now pose to get a new set this week in just 20000 miles. but i had some suspension problems. slack in inner tir rod, rotted out rack bushing, no allignment in 5 years, worn out shocks and coils.
all new now, new rack and pinion, new poly sway bar bushings, new bilstein 5100 shocks , new coils, new new poly rack bushings. all new for the front.
i would love to get 40k out of a set.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 05-03-2011, 05:33 AM   #5 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 49.12 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Have you since tried to increase the pressure further to get more even tyre wear ?
It worked for me
Lifetime fuel consumption :
Old 05-03-2011, 08:45 AM   #6 (permalink)
EcoModding Newb
Acura TSX - '06 TSX
90 day: 29.15 mpg (US)
Lafawnda - '01 CBR600 F4i
90 day: 46.15 mpg (US)
I have increased my pressure from 32 to 45 psi in the hopes of getting better mpg and getting more even wear on my tires. It may help even the wear slightly, but I still expect the outsides to go first. My understanding is that modern radials don't change wear patterns as much as tires of the past.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 07:47 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 09:45 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 02:38 AM
Riddle Me This! Abnormal Tire Wear trebuchet03 General Efficiency Discussion 21 10-30-2008 03:30 PM
