Originally Posted by geeteethree
If you do have access to EKTA, the part number on my undertray is 1LO 825 235, very similar to the one listed above. Please note that my one does not have the service access shaped around the sump.
OK thanks, btw FYI it is always "0" (zero) and not "O" when it comes to VAG part numbers
![Smile](/forum/images/smilies/smile.gif)
no big deal except for when someone wants to copy and paste them
Yeah it seems to be very similar, I wonder what's dif on the 1L0 vs. 1H0 (VW version):
Auto Parts Seat - parts catalogue. Auto Parts for Seat
BTW It would appear that the "-235A" is the one used on 1Z hence TDI.
Do you have any info as to why they'd use the Seat one instead of the VW version? It is true that early Seat models were closely related to the Mk1 Jetta but the Toledo you mention would be Mk3 related, so I wonder why someone started using it instead of the Golf/Vento version? Do you have a thread for this discussion? Just because a Seat cover I'd have to import whereas a mk3 I could find locally.
