Old 03-01-2010, 04:54 PM   #31 (permalink)
Originally Posted by ChrstphrR View Post
And, you'll likely have to add wings anyway, like COCyclist did on his, to cover the bits the cover anyway.
Well again we are NOT talking Mk4, but Mk3/Mk2 there is no "wings" on the Mk3 design, as you can see if you click on the link I posted above and quoted here:
Old 03-01-2010, 04:56 PM   #32 (permalink)
Originally Posted by geeteethree View Post
If you do have access to EKTA, the part number on my undertray is 1LO 825 235, very similar to the one listed above. Please note that my one does not have the service access shaped around the sump.
OK thanks, btw FYI it is always "0" (zero) and not "O" when it comes to VAG part numbers no big deal except for when someone wants to copy and paste them
Yeah it seems to be very similar, I wonder what's dif on the 1L0 vs. 1H0 (VW version): Auto Parts Seat - parts catalogue. Auto Parts for Seat
BTW It would appear that the "-235A" is the one used on 1Z hence TDI.
Do you have any info as to why they'd use the Seat one instead of the VW version? It is true that early Seat models were closely related to the Mk1 Jetta but the Toledo you mention would be Mk3 related, so I wonder why someone started using it instead of the Golf/Vento version? Do you have a thread for this discussion? Just because a Seat cover I'd have to import whereas a mk3 I could find locally.
Old 03-01-2010, 05:02 PM   #33 (permalink)
Found it! THANKS
MK2 engine undertray - Page 3 - Club GTI
Old 03-01-2010, 05:04 PM   #34 (permalink)
I finally ordered an oil extractor (got tired of oil here/there all the time ) so I wouldn't even mind closing it up completely
Old 03-01-2010, 05:04 PM   #35 (permalink)
WannaBe
geeteethree's Avatar
16VT - '90 VW Golf GTI 16v
Polo TDI - '99 Volkswagen Polo CL TDI Estate
Diesel
90 day: 47.76 mpg (US)
[QUOTE=G2TDI]Found it! THANKS
Post 16 is me
Old 03-01-2010, 05:05 PM   #36 (permalink)
Found it! THANKS
Post 16 is me
Yeah reading now
Old 03-01-2010, 05:11 PM   #37 (permalink)
I wonder which Seat version this is (from pg1 of that thread)
For this particular purpose I want it I'd be even willing to go for this completely closed one!
Old 03-01-2010, 05:24 PM   #38 (permalink)
WannaBe
Diesel
That's the very one I'm using, part number as detailed above.
It has been a very successful mod, reducing engine and wind noise, keeping belts dry in wet weather, and keeping the engine bay clean. Air flow in the engine bay has improved as now controlled; entering through lower bumper and grille, out behind the subframe. I'm using slimline electric fans on the rads, with can be controlled via switch on dash when in traffic or cooling down after a blast; my 250hp engine generates a lot of heat!
Old 03-01-2010, 06:48 PM   #39 (permalink)
When you say very one I assume you're talking about the last one I posted?
I thought your would have an opening as you mentioned you have a service opening?
Old 03-01-2010, 07:17 PM   #40 (permalink)
WannaBe
Diesel
no service access, so have secured it using wingnuts for easy removal, should emergency roadside repairs be needed (thankfully they haven't, so far).
I am looking to fill the space between the front spoiler and the undertray, probably with a plywood splitter (pun intended as it's pretty low!).
Regards, Grant
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
Biodiesel UK test VW Golf - MPG results pending sallen Fossil Fuel Free 5 02-20-2010 12:09 PM
New York Auto Show: VW Golf Wins World Car of the Year Award SVOboy EcoModder Blog Discussion 1 12-18-2009 05:46 AM
Swapping big cars for small! drivingsteve Off-Topic Tech 18 09-04-2009 06:17 PM
[VIDEO] Small v. Big Cars and Safety SVOboy General Efficiency Discussion 20 12-05-2008 05:14 PM
