Old 03-02-2010, 05:49 PM   #5 (permalink)
comptiger5000
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Busypaws - That depends on whether or not the car uses a return type fuel system. Not all do. Some use a variable speed pump (or a pressure switch and regulator) that only feeds as much fuel is needed. Therefore, during DFCO, these systems would turn the pump off, as no fuel is required.
