Old 03-03-2010, 03:55 PM   #134 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I actually slump glass all the time. I have a large kiln I made for firing my glass art. Christ was bang on about slumping lam. glass. Not possible.
Laminated windshields are slumped with the two layers separated by a special powder so they don't fuse. That way they will have a uniform gap between them for the plastic layer to be vacuum bonded to. They are not tempered so they could be carefully cut. Abrasive water jet would be a good way but I'm not sure about how they would deal with the curved glass. A fine grit diamond wet saw could do it.
I bet custom laminated windshields would cost a king's ransom outside Cuba. Best bet would be to find a junked MG or something like that.
Acrylic is far easier to deal with and can be polished if scratched. It's a one step bending process. You can also get it with a teflon coating which helps resist scratching.
It's pretty easy to make a hot wire bending tool for acrylic. See Instructables. You would be limited to straight bends though instead of curved. Would still look nice and vintage.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
