03-03-2010, 05:13 PM
Pokémoderator
LED Headlight for trucks ...
Hello -
If you have a round headlight, this may be your bag :
03/23/2009 - World's First 7" Round LED Headlamp Shows Bright Possibilities for Commercial Applications
March, 2009, Falconer, New York - The 12 volt extended product line release of the world’s first 7” round LED Headlamp has enabled Truck-Lite to come full circle as your premier See & Be Seen® LED lighting supplier, lighting your way from the front of the truck to the rear of the trailer. This new and exciting LED Headlamp innovation provides a new level of performance for 7” round forward lighting 12 volt applications, offering the extended life and energy efficiency of light emitting diode technology.
Truck-Lite - Catalog Product : 7'' Round 12v LED Headlamp
- DOT Approved, High Beam and Low Beam performance
- Provides light output closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
- Solid-state design resists damage from shock & vibration
- Offers as much as 50x longer life (10,000 hrs vs 400 hrs) than comparable incandescent lamps, saving the time and expense of replacing lamps multiple times
- Hard wired design, fully encapsulated electronics & anodized aluminum housing protect from damage caused by corrosive elements
- Impact resistant polycarbonate lens protected against damage caused by debris and other hazards
- Direct replacement for Par 56, H6014 and H6024 lamps
- 3-Year Limited Warranty
- 24v Version available, Part No. 07370
Light Source:
10 Light Emitting Diodes (LEDs)
Designed at 12.8v
4.5a (High Beam), 2.5a (Low Beam)
CarloSW2
