Old 03-05-2010, 04:16 AM   #48 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Lots of pics as promised.
First, Here's the shot of the transaxle warmer. Now 750 watts. Fast heat! Plumbed into the drain plug with a custom nipple. This is the lowest point on the transaxle, beside the oil pan. Just a copper elbow brazed onto the drilled out drain plug.
There is the tank heater and the y it came with plumbed into one of the transaxle coolant lines. Look for the pink.
Now the engine heat:
This is the Y I made to plumb into the top rad hose.
This is the engine heater hot return installed. It will percolate back into the head from here.
This is the low/cold side nipple installed where the coolant drain used to be. There's room back here but not a lot of vertical so the heater will have to be mounted at a 45˚ angle. Should be OK.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
