what about a complete 6502 based microcomputer board with ram , rom , pia and address decoding all built on a slab of plain matrix board with each connection hand soldered. 8 bit data bus , 16 bit address bus and cant cross each other!
AND using a manual eprom programmer. Setting up each byte and address with dip switches and toggling the r/w line. Took some time to fill up a 4k eprom
After that i graduated to an 8086XT with a homemade eprom programmer running dos 4. bleeding edge stuff.
this was the genesis of Bauer's first law of electronics:
Keep it simple.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
