Old 03-06-2010, 10:28 PM   #56 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
A 1500 watt load should be fine with a short 16 or 14 gauge cord on a 15 amp outlet. Most space heaters are 1500 watts. You could also get away with lower watt heater on for longer. I got the 1500 watt one because I also want to heat up the interior a bit as well. The ladies like that.
I'm almost finished the install. While I was at it I also installed a disconnection relay in the 12V supply from the DC-DC converter so I can kick it on when the battery pack gets low.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
