Originally Posted by Flatmann100
Paul, I connected the 12 volts, but the LEDs did not come on.  I'll start checking other areas on the control board for voltage. Any suggestions?
I would start by checking the orientation of diode D1.
Also check your polarity of the 12V supply and that it is above the minimum 9V.
-Adam
