In the Prius 70˚ is the magic number at which point FE savings are largest because once you reach that the engine doesn't run when it's not needed.
I also have sealed off my engine compartment with a grille block and foam weather stripping to keep all that heat in.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
