Old 03-08-2010, 05:41 PM   #16 (permalink)
Peter7307
Originally Posted by cfg83 View Post
Peter7307 -
Thanks for posting this. This is what I mean by a side-effect. Do you remember if the "fancy alloy spoked pulley" was OEM or ???
I think a light weight pulley may introduce the same problems because it's not OEM. That is why I wanted to know if someone on a Hyundai forum had done this.
CarloSW2
Carlos,
The one I was talking about was a set of after market pulleys fitted as part of a marine conversion of a diesel truck engine converted to marine use.
The set was to drive the water pump , two alternators and an idler for tension and to delete the power steering pump.
I was not involved in the original installation (if I had been I would have done more than a few thing differently but that is another issue) and so far as I know they were bought from a boat supply place as a set.
Hope this helps , Pete.
The Following User Says Thank You to Peter7307 For This Useful Post:
cfg83 (03-08-2010)
