Originally Posted by suspectnumber961
I've tested napathlene, but if you use too much it makes carbon black...smokey exhaust...plus stinks like whatever. You can only keep so much of it in suspension depending on temps...any more and it precipitates out....but probably would just hang in your fuel filter till it dissolves again.
Sounds like you didn't follow directions, OBDII <- Again this trick DOES NOT WORK in a non-automatically tuning car, works just fine OBDII without excess smoke your timing will just turn WAAAYYY back. Low end power improves, exhaust is cooler and FE jumps. Added to an OBDI or Carburated setup your power decreases, car runs like molasses and your spark plugs fowl unless you retime the thing...
Powdered it is 100% dissolvable in bezene which means 4% of fuel (give or take) can be nap
Cheers
Ryan
