03-10-2010, 04:34 PM
#33 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Originally Posted by rmay635703
Sounds like you didn't follow directions, OBDII <- Again this trick DOES NOT WORK in a non-automatically tuning car, works just fine OBDII without excess smoke your timing will just turn WAAAYYY back. Low end power improves, exhaust is cooler and FE jumps. Added to an OBDI or Carburated setup your power decreases, car runs like molasses and your spark plugs fowl unless you retime the thing...
Powdered it is 100% dissolvable in bezene which means 4% of fuel (give or take) can be nap
Cheers
Ryan
What kind of FE jump can we figure on?
