Old 03-12-2010, 09:56 AM   #28 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
On another thread Aerohead suggested putting ballast in the car to simulate driver and passenger weight before determining the correct angle for a boattail from the template. As I recall, you said you need to haul things in your truck bed from time to time. I had this thought that it may be better to be conservative in your angles (as I think you are) than to get them just right and have it too steep as soon as you put a load in the bed of the truck.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
