Originally Posted by jackbauer
One thing i've been thinking about is a brake signal input to the controller. Perhaps just a 0v , 5v on an unused icsp pin. Similar setup to the "safety code" that paul wrote but if it sees the brake signal applied it automatically commands zero pwm. If after zero pwn is achieved it sees power flowing to the motor it open the main contactor. thoughts?
This is something that I was planing for the expansion board. The problem is if the code is added for the isp port, it will make it more difficult to add the expansion board.
-Adam
