Originally Posted by MPaulHolmes
Hi Flatman! I done figured it out! oh ya. You have to change the precharge wait time to greater than 0. The default is 0. Try maybe 30 or 60 or something. That would be 3 to 6 seconds of delay before the controller would close the contactor.
with the serial hooked up, type "config"
That will show all the current variable settings.
Now type:
pc-time 40
save
That will set the precharge time to 4 seconds. Then it will save it to eeprom. Now turn off the controller and on again, and the main contactor will close after 4 seconds.
PAUL!!
Im ashamed of you.
The creator of the controller doesnt even kow all of the commands!!
Mike, If you just type restart, the controller will reboot without needing to cycle the power.
-Adam
P.S. Im just pulling your leg Paul, Your doing great!!
