Old 03-17-2010, 07:54 AM   #3201 (permalink)
EVVette - '71 Chevy Corvette Coupe
Originally Posted by MPaulHolmes View Post
Hi Flatman! I done figured it out! oh ya. You have to change the precharge wait time to greater than 0. The default is 0. Try maybe 30 or 60 or something. That would be 3 to 6 seconds of delay before the controller would close the contactor.
with the serial hooked up, type "config"
That will show all the current variable settings.
Now type:
pc-time 40
save
That will set the precharge time to 4 seconds. Then it will save it to eeprom. Now turn off the controller and on again, and the main contactor will close after 4 seconds.
PAUL!!
Im ashamed of you.
The creator of the controller doesnt even kow all of the commands!!
Mike, If you just type restart, the controller will reboot without needing to cycle the power.
-Adam
P.S. Im just pulling your leg Paul, Your doing great!!
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 03-17-2010, 09:52 AM   #3202 (permalink)
PaulH
MPaulHolmes's Avatar
Hi Jack! Once I found out that the stupid, stupid, stupid, um... stupid DC-DC that I was going to use doesn't work as a high side driver supply, I fell into a deep depression, and forgot to send it, since I really doubt that it will work anyway. hahaha. The good news is, I finished the next version of the control board which has a high side that should actually work now (and has rs232 and CAN). If you want one of the other boards still, I can send you one, but pwm'ing the high side almost certainly won't work on this board, if you are above like 12v for the power section. Joe tried it and it kept latching up his microcontroller.
Actually, I need to see if they still exist, since I may have thrown them in the garbage, on account of my anger. hahahaha. I'll look around the room and see if my wife pulled them out of the garbage.
Adam............... I may not know all the controls, but at least I um..... can make a really crappy SR board that doesn't work! hahahahaha. I swear I'm over the anger of the stupid ugly, control board that doesn't work... Unbelievable. It doesn't work! I'm a simple man. A man who wants... Nay! Needs a Synchronous rectification control board that works!
kits and boards
Old 03-17-2010, 09:59 AM   #3203 (permalink)
jackbauer's Avatar
No problem Paul i'll wait for the new revision.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-17-2010, 10:18 AM   #3204 (permalink)
PaulH
Here's the new one. It has some surface mount parts on it though. (resistors and caps is all. 0805, 1206, 1210). I watched a video on it on youtube, and soldering didn't look so bad anymore. You just need solder flux.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
sawickm (03-17-2010)
Old 03-17-2010, 11:32 AM   #3205 (permalink)
jerpelea please contact me at aironix2003@yahoo.com
Old 03-17-2010, 04:43 PM   #3206 (permalink)
ReVolt Enthusiast
Hey Paul,
Hang-in there !!!
Keep up the good work !!!
We are all cheering you on.
-Mark
Old 03-17-2010, 08:11 PM   #3207 (permalink)
Hey Paul, do you have a schematic of the SR control board I could look at?
I have learned a few things from designing the power section of a 3 Phase Inverter that can be applied to a SR controller, so maybe I can give a few hints.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
Old 03-17-2010, 08:28 PM   #3208 (permalink)
also is the schematic on the wiki up to date?
I've been spending a lot of time pouring over it, and the mechanisms in it. I'm re-reading the entire thread to see If it can answer the questions before I bug everyone. I am coming up with many questions regarding the design.
Old 03-17-2010, 09:43 PM   #3209 (permalink)
PaulH
I think the wiki schematic is up to date for rev. 2C. The australians done made their own improved version, though.
I don't have a good way of posting the schematic in picture form. It's too dang big. any suggestions?! my crap software won't allow it to be saved as a pdf.
kits and boards
Old 03-17-2010, 09:57 PM   #3210 (permalink)
I sent you a PM.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
