Old 03-19-2010, 03:05 PM   #2 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
first thing that comes to mind is that there is a line with coolant in it that keeps the throttle body from icing up, it's about the size of the PCV hose, make sure that is not swapped with a vacuum hose.
Did you use a new intake manifold gasket when you put everything back together?
