Old 03-21-2010, 02:27 AM   #9 (permalink)
k.civic.f4i
recession proof rebel
k.civic.f4i's Avatar
Originally Posted by Hondork View Post
Also, the Si wiring harness has no provision for EGR, in addition to the 5-wire O2 sensor problem mentioned earlier. Even if you get a VX engine with its harness, the body harness that connects the engine harness to the ecu is missing the extra VX only 6-pin connector that carries the additional O2 information as well as EGR info to the ecu. Then you also need to get the EGR control box (black box that mounts to the firewall with vacuum tubes going in and out) and wire that in as well. Honda for some reason sends the 2 wires that control this thing not through the engine harness but through the wiper harness that goes through the firewall on the driverside. Annoying.
'93 Civic Si hatch D16Z6 engine w/ VX transmission? - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum
can anyone verify the thing about the body wire harness?
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
