Ok,
So I have the car back running like it should (other than the slight dead pedal...o2 sensor), but I still have coolant burning and coming out the exhaust (ALOT). I have looked at the Helms manual and everything looks to be connected like it should
. I did a compression check, but I don't have a leakdown tester to see if I have a headgasket problem (which wouldn't make any sense for it to blow while I removed the intake gasket). I am really stumped here... any help is appreciated.
