Originally Posted by Flatmann100
I am reading 0-8-0 volts when I go from off throttle to full at the gate leads to the FETS......
8 volts? is this the voltage from gate pin to source pin? This should be 12V (assuming you get to wide open PWM so the duty cycle is 1). Perhaps your 12V source to the controller board is weak? Is the output from the DCDC a full 12V?
are your wheels off the ground?
The controller can display all the settings. Not sure what it is in RTDexp, but from a terminal I think you just press Enter. Can you share what all the settings are?
