Old 03-25-2010, 06:57 PM   #3269 (permalink)
jyanof
Joe
Originally Posted by Flatmann100 View Post
Joe, I am testing at say GR1 to any of the other GR's and the ground of the control board. I also Tested 8V at "R21" Resistor before I went to the gates.
Battery pack is totally separate.
I have the power LED on.
Would I not see a "UVFail" signal at pin 11? If the output from the DC-DC was bad?
Ya you should... the 8V thing is weird... I'm still not sure if you're using the right ground reference. can you measure the voltage across pins 1 and 4 on the mosfet driver, u7?
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
