Old 03-26-2010, 02:23 PM   #15 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
does it do or does it doesn't?
If flow is attached down to the bumper Ernie's wing would do nothing.
Frank, I realize you are the master of brevity but are you saying you think Ernie's wing helps reduce drag or are you suggesting it has no value?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
