Old 03-26-2010, 02:37 PM   #30 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I'm following with interest too. Sometimes I absentmindedly search for one more gear after 5th, on the highway. I'm not sure I would want to lose cruise control. Do you expect to still have it after the swap?
I have done the CV boots with the axles on and off the car. Do it now with the axles out. It takes a little time and perhaps a special boot clamp tool but it's a way better solution than messing with the split boot repair. Also, the outer boots generally take more of a beating than the inner ones so you may be safe to keep the inner boots.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
