Thread: rear diffuser
Old 03-26-2010, 05:49 PM   #26 (permalink)
aerohead
angle determined by origin of diffuser
Originally Posted by fabrio. View Post
I am confused from two image below, can you help me to understand wich is the reality?
From the diagram,if the diffuser begins ahead of the rear suspension,go with 2-1/2-degrees maximum.
If it begins behind the rear axle go with 4-degrees maximum.
The 7-degree recommendation may be a compromise to road clearance and not really about aerodynamics.
