Old 04-16-2008, 12:38 PM   #11 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
I am confused from two image below, can you help me to understand wich is the reality?
The Following User Says Thank You to fabrio. For This Useful Post:
UltArc (10-08-2012)
Old 04-16-2008, 01:30 PM   #12 (permalink)
DMC - '99 Honda Civic DX
Originally Posted by fabrio. View Post
good clear work Compass, thankyou for your prensence
I think (but), that in your rear diffuser, the sepaation point of flow, isnt' fixed because, the rear end of pannel is too up curved
This one, cause not predictable turbolence (i think)
It's Compaq...
it's suppose to curve...imagine blowing into a straw...
_____________
____________/ <-------straw A
_____________
_____________| <---- straw B
Now which one are you going to have an easier time blowing...A or B?
The answer is A...because B your air get concentrated and you have less space to work with...
A on the other hand flows more freely and exits more smoothly cause less drag...
Old 04-16-2008, 02:01 PM   #13 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by Compaq888 View Post
It's Compaq...
_____________
_____________
Right, but I think what Fabrio means is that it abruptly curves upward, which can create turbulence. "Straw A" does not equate to your design:
Straw "C":
______________
____________J
It looks like it would need to be flush with the rear bumper as well -- the air goes upward and gets trapped.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-16-2008, 02:33 PM   #14 (permalink)
Straw "C":
______________
____________J
RH77
It does abrupty turn upward but it's curved such a way that air exits after the bumper and not inside the bumper...
I went through 2 previous designs until I got it right on this one...
_____________
____________J
I made a little improvement on your design which clearly shows that air never hits the inside of the bumper...
All the aero stuff on my car and increased tire pressure only increased my hwy mpg +10...giving me about 39mpg hwy...but for the city I got 23-24mpg and I drove most city so I had to get rid of the car...
The car I currently have gets 35-36mpg city and 48.x on the freeway...those numbers are hypermiling of course...If you aren't satisfied get a more efficient car...
Old 04-16-2008, 03:16 PM   #15 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Just going to chime in here to the original post with this....
That's a Noble M12 GTO
We measured the diffuser angle to be a tiny tiny bit less than 10 degrees with a digital angle finder (horizontal was set as the shop floor and measured with the car on the ground).
Note the little winglets pointing down to keep air from the tires/side from interfering with the faster flow through the diffuser....
For last year's HPV (The one in foreground), diffuser angle = 10 degrees with something like an 8 degree inlet in the front. These planes don't intersect - there's a flat region from the wheel well area to a little bit behind the wheels.
Those angles were not arbitrarily chosen
Originally Posted by compaq
I used common sense..make sure the air flows and doesn't get stuck anywhere...
Straw "C":
______________
____________J
RH77, I think Compaq is fixing a problem of a parachute type effect as opposed to what Fabrio is looking for (something to do stop "parachuting" and work as an effective diffuser). But, Compaq, as a diffuser - that shape is not optimal. The curvature eventually reaches an angle that is way too steep for flow to stay attached without separating "cleanly." Optimal? No. Effective? Possibly. There's no room for all or nothing
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
The Following User Says Thank You to trebuchet03 For This Useful Post:
UltArc (10-08-2012)
Old 04-16-2008, 04:52 PM   #16 (permalink)
fabrio.'s Avatar
sorry for your nik Compaq, and sorry for my explanation, my English isnt' good, but trebuchet has answered correctly.
I do not refer at the flow direct to bumper, but at the excessive curvature at the end of your diffuser.
The energy of flow, is to small for to follow the profile of diffuser...
Do you know the reserce by mitzubishi about the VG?
Mitzubishi has applyed the VG at the rear of roof for to direct the air flow down direction because, the rear window of lancer sedan is too angled and the flow distact from window.
Old 04-16-2008, 05:03 PM   #17 (permalink)
MechE
Here's the research paper published by Mitsubishi
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Old 04-16-2008, 05:09 PM   #18 (permalink)
fabrio.'s Avatar
trebuchet, thankyou for your exhamples.
In my case, I reserch only drag reduction, all my work its focuses they.
Cases A and B of diagram above posted by me, says that the best angle for drag reduction is from 2 and 4 degrees, I know that the reserce of diagram its realative at model with flat underbody, with or widhout wheels I do not know, the height from ground , I do not know.
I know, that some aerodynamic cars like the Loremo, Bionic by mercedes, Opel G90 and more others cars, they have diffusers angle whit more 7° degree.
I think, that optimal angle of diffuser depend also by inclination roof, rearwindow and declidt...corrected ?
It is possible, that the optimal diffusor angle, depend also by point of intersecation of upper flow with the under car flow? may be, that the intersecation point of two flow, it must at the centre of car in according with the front stagnation point?
Old 04-16-2008, 09:19 PM   #19 (permalink)
MechE
For our cars, I don't think flow interaction from the top and bottom are significant - because our cars are bluff bodies. For very streamlined shapes, yes - that will be a bigger concern. But, in my opinion, most of the losses for that section of our cars are due to wake rather than intersecting flow regions... That's just a guess - testing/analysis would be really useful here.
It's actually a good idea to look at other cars with diffusers to see what they have. Being that they're cars, they'll have a similar (at least somewhat comparable) ride height and a comparable height to length ratio.
Old 04-17-2008, 12:37 AM   #20 (permalink)
That was the most effective shape possible on a $20 budget...Yes I could of done a lot more and could of had something better but that would require a lot of money. You got to draw the line of how much spending to get better FE you're going to do...My design was simple and effective...I wanted to do the whole underbody of the car and finish off with a crazy diffuser but that would of wasted a lot of money..
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Video: tuft testing (rear) 1993 Ford Mustang notchback MetroMPG Aerodynamics 12 02-05-2011 09:40 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 12:33 AM
