Old 03-27-2010, 01:35 AM   #30 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Nerys View Post
So far its liking the gas just fine. Someone I talked with today suggested that my fear over the presence of water in my washed gas might explain it running smoothly now. He said they used to use water injection to boost equivalent octane or something like that something about compensating for lower octane in higher performance engines. Smoothing out the flame front or something.
Take care the water you use does not have chlorine in it also remember water in your gas is very different than water injection.
Pitting and corrosion issues abound in water laden fuel as old telephone suggests.
Even though water and gas don't really mix there will be some emulsion because gasoline contains many other compounds other than gasoline, some of which will react to water. The issues (if they occur) will be long term and won't be noticed for a while.
Cheers
Ryan
